Is it possible to set RGB style constant glow in Pironman v.2 without preset effects
I’m very sorry, I don’t quite understand what you mean. I suggest you describe your problem in detail.
- Our pironman software has four display modes for you to choose from: breathe, leap, flow, raise_up.
For example: sudo pironman -rs leap - You can also modify the RGB colors by yourself.
You can use the RGB color comparison table to choose your favorite color:
https://tool.oschina.net/commons?type=3
For example, if you want to change the RGB color to Red (as shown in the picture):
sudo pironman -rc FF0000
I want the LEDs to just burn in one color without modes, such as breathe
We’ve taken your feedback on board, and now we’ve added a static mode which is also equivalent to no mode.
It means that the current RGB color is always lit.
Now you need to update your code base:
cd ~/pironman
git pull
After successful installation, reboot the Raspberry Pi.
Go ahead and run the sudo pironman -rs static command again to do so.
Thank you. This is exactly what I wanted.
