Just had a play with Stressberry.
This graph is of the CPU fan doing its thing in Auto, and the Case fans are set to Performance (they never came on in this test):
This next graph is the Case fans on Always On:
Raw data if anyone wants it:
pi@raspberrypi:~ $ stressberry-run out1.dat
Awaiting stable baseline temperature…
Current temperature: 38.9°C - Previous temperature: 42.2°C
Current temperature: 38.9°C - Previous temperature: 38.9°C
Preparing to stress [4] CPU Cores for [300] seconds
Idling for 150 seconds…
Current temperature: 38.9°C - Frequency: 1600MHz
Current temperature: 39.5°C - Frequency: 1500MHz
Current temperature: 39.5°C - Frequency: 1700MHz
Current temperature: 38.9°C - Frequency: 1500MHz
Current temperature: 37.8°C - Frequency: 1700MHz
Current temperature: 37.8°C - Frequency: 1600MHz
Current temperature: 37.3°C - Frequency: 1700MHz
Current temperature: 38.4°C - Frequency: 1600MHz
Current temperature: 37.8°C - Frequency: 1500MHz
Current temperature: 37.3°C - Frequency: 1500MHz
Current temperature: 38.4°C - Frequency: 1500MHz
Current temperature: 37.3°C - Frequency: 1600MHz
Current temperature: 36.7°C - Frequency: 1500MHz
Current temperature: 36.2°C - Frequency: 1600MHz
Current temperature: 36.2°C - Frequency: 1500MHz
Current temperature: 35.6°C - Frequency: 1500MHz
Current temperature: 35.1°C - Frequency: 1500MHz
Current temperature: 36.7°C - Frequency: 1600MHz
Current temperature: 35.6°C - Frequency: 1600MHz
stress: info: [153606] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd
Current temperature: 41.7°C - Frequency: 2400MHz
Current temperature: 42.8°C - Frequency: 2400MHz
Current temperature: 43.3°C - Frequency: 2400MHz
Current temperature: 43.9°C - Frequency: 2400MHz
Current temperature: 44.4°C - Frequency: 2400MHz
Current temperature: 45.5°C - Frequency: 2400MHz
Current temperature: 45.0°C - Frequency: 2400MHz
Current temperature: 46.1°C - Frequency: 2400MHz
Current temperature: 46.6°C - Frequency: 2400MHz
Current temperature: 47.2°C - Frequency: 2400MHz
Current temperature: 47.7°C - Frequency: 2400MHz
Current temperature: 48.3°C - Frequency: 2400MHz
Current temperature: 48.8°C - Frequency: 2400MHz
Current temperature: 49.9°C - Frequency: 2400MHz
Current temperature: 49.4°C - Frequency: 2400MHz
Current temperature: 51.0°C - Frequency: 2400MHz
Current temperature: 50.5°C - Frequency: 2400MHz
stress: info: [153606] successful run completed in 300s
Current temperature: 41.1°C - Frequency: 1500MHz
Current temperature: 42.2°C - Frequency: 1500MHz
Current temperature: 42.8°C - Frequency: 1500MHz
Current temperature: 42.2°C - Frequency: 2400MHz
Current temperature: 41.7°C - Frequency: 1600MHz
Current temperature: 40.6°C - Frequency: 1600MHz
Current temperature: 41.1°C - Frequency: 1600MHz
Current temperature: 41.7°C - Frequency: 1500MHz
Current temperature: 40.0°C - Frequency: 1500MHz
Current temperature: 40.6°C - Frequency: 1500MHz
Current temperature: 39.5°C - Frequency: 1600MHz
Current temperature: 40.0°C - Frequency: 2400MHz
Current temperature: 40.6°C - Frequency: 2400MHz
Current temperature: 38.9°C - Frequency: 1700MHz
Current temperature: 38.4°C - Frequency: 1700MHz
