Turn on pironman 5 via IR remote control?
Can you also switch on the Piroman5 case using an IR remote control (Xbox One FB), and if so, how?!?
kann man das Piroman5 Gehäuse auch per Fernbedienung IR (Xbox One FB) auch anschalten , und wenn ja wie ?!?
Danke im voraus.
The Pironman 5 case itself does not support directly turning on with an infrared remote control (including the Xbox One remote). The infrared receiver on the Pironman 5 case provides the hardware foundation for controlling the Raspberry Pi via infrared remote, but implementing the “power on” function requires complex software configuration and possible hardware modifications. More practically, the remote can be used to control media playback or execute system commands.
That’s a shame! The Argone One V1 could do that. Your case is worlds better and can’t do it. But thanks for the info. But maybe it will come someday, I hope.
Thank you for your feedback and recognition!Currently, the hardware design of the Pironman 5 does not support power-on via infrared due to the power management architecture. However, we have noted your request and will carefully assess the possibility of adding this feature in future versions or products.
that gives hope :slight_smile: thank you very much
keep it up
