At present, our SD expansion board has been upgraded to version V14. Weirdyguy, have you tried it and what was the result?
I didn’t get the chance to try this version. After 3 différents versions, I just give up. I’ve remove it, cut the 2 holders to keep the gaps with rpi board. If I need to use SD card, I pass through an USB adapter. But if you are sure at 200% that it fix the issue… Send it.
Please contact service@sunfounder.com to get the V14 version SD board.
Hi there, i’ve reveiced V14 SD extender, install it and no change. There’s delay during shutdown, reboot and booting when SD extender is install and when there’s no SDcard into it. As if rpi board know there’s something into SD card socket but there’s no communication because there’s no sd card pluged into the extender… The only way to get no delay is to leave an empty sdcard into extender or to remove extender from rpi board. so no, the V14 doesnt fix the issue. Sorry try again…
