built the GalaxyRVR and was able to get through uploading the play software to the R3 board, however, have been unable to find the “GalaxyRVR” network to connect the device to a phone for the controller.
any tips or where I could be going wrong?
Please follow the tutorial steps:
https://docs.sunfounder.com/projects/galaxy-rvr/en/latest/play_mode.html
Move the expansion board switch to the right side and upload the galaxy-rvr.ino code to the UNO board.
After the code has been uploaded successfully, do not unplug the USB cable yet.
To activate the ESP32 CAM, move the mode switch to the run position and press the reset button to reboot the R3 board. Then you observe if the light blue light flashes on the bottom strip. Open the IDE serial monitor again and look at the print information and provide us with the print information.
thank you, we had the switch in the wrong place
