I made the Picrawler without wifi, installed all the things the website recommend and assembled the unit. It just sits there. How do I use it and get it to move around without connecting it to the internet or a phone? Also can I slap a Raspberry Ai chip on it and have it be self learning?
If you want Picrawler to work, it does require an internet connection.
You can follow our tutorial, there are two ways to operate it.
Option 1: Control Picrawler using Python commands. You need to install the Raspberry Pi system, then install our code library, and then use commands to run it.
https://docs.sunfounder.com/projects/pi-crawler/en/latest/python/play_with_python.html
Option 2: Use our ezblock studio APP to control Picrawler. You need to install the ezblock OS image system we provided, then connect and work with the APP.
https://docs.sunfounder.com/projects/pi-crawler/en/latest/ezblock/play_with_ezblock.html
