Hello there,
I don’t seem to have had any issues installing the software, and running the default configuration or putting this kit together. However, in such default mode, the LED D3 on the main board does not seem to work or switch on (all the others work correctly in blue and the rgb strip also works well in blue). If i change the config to colorful, then this particular LED blinks in green (in quite a predictable pattern), and if i change the pwm setting instead, then this LED blinks (fast) through all the range of colours. It seems the LED works therefore but behaves quite erratically. Do I need a replacement board, or this an expected behaviour due to bad software developing? All the remaining LEDs and RGB strip and OLED screen seems to work well and as intended.
I have to say that when changing the colour to purple instead of blue, but while leaving the rest of the setting still on breath, the D3 LED also blinks green in the same manner. Blue setting keeps the D3 LED switched off and any other different colour makes it blink in green.
Also, Would someone also explain to me the reason for the config settings of rgb_blink and rgb pwm? what does changing these settings really do in actual practical terms?
I think I have also experienced that when setting the config settings to leap or flow, then the LED opposite of D3 underside/underneath D3 sometimes blinks in white erratically as well. It does it every so often, and does not seem as erratic, or as faulty, as the D3 LED though.
