Default setup, led 4 not working on Pironman5
After assembling and testing all seemed to work fine. But after a while i noticed that only 3 of the 4 default leds where blinking. There seemed to be no delay between led 3 switching off and led 1 going on… Strange. After updating the default config of 4 leds to 5, all 4 leds are blinking fine.
Also, although not everyone will install an aditional led strip of a few leds, it would be fine if the number of active leds could be changed from the dashboard.
We suggest you provide us with a video of the problem so that we can analyse and solve the problem.
If the video is large, please upload the recorded video to onedrive, then share the video link with us and give us access to it.
Set number of leds to 4, only 3 blink
https://1drv.ms/v/s!AqYxE9egz5-9gspBS4u4mj29HkuQmQ?e=CvfOpd
Set number of leds to 5, 4 leds blink as requested
https://1drv.ms/v/s!AqYxE9egz5-9gspAVSL0lmPM83jB8Q?e=KUyDYH
The issue has been fixed.
Please run the following command to update the code:
cd ~/pironman5
git pull
After successful installation, just reboot the Raspberry Pi.
