THANK YOU FOR YOUR REPLY!
The reboot still happens the same with the pironman Python software disabled per your instructions.
The reboot does not happen with the USB-C power connected directly to the Raspberry Pi power socket but the pironman does not function properly that way of course.
The reboot occurs randomly but within 5 minutes whenever the RTL-SDR dongle is plugged into any USB port and it occurs much more quickly when the actual SDR app (CubicSDR) is started up but the dongle works normally until the crash occurs and I can tune in frequencies etc for a few seconds. When the crash occurs, the hdmi screen just goes black - there are no messages.
Here are the logs of two consecutive startups. The crash/reboot is between the two.
------------------------23/07/18 14:09:50------------------------
pironman version: 1.6.2
username: pi
config_file: /home/pi/.config/pironman/config.txt
Kernel Version:
Linux playroom 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
OS Version:
No LSB modules are available.
Description: Debian GNU/Linux 11 (bullseye)
PCB info:
Revision : c03112
Model : Raspberry Pi 4 Model B Rev 1.2
23/07/18 14:09:50,922 [DEBUG] power_key_pin : 16
23/07/18 14:09:50,922 [DEBUG] fan_pin : 6
23/07/18 14:09:50,922 [DEBUG] rgb_pin : 12
23/07/18 14:09:50,922 [DEBUG] update_frequency : 0.5
23/07/18 14:09:50,922 [DEBUG] temp_unit : C
23/07/18 14:09:50,922 [DEBUG] fan_temp : 65.0
23/07/18 14:09:50,923 [DEBUG] screen_always_on : True
23/07/18 14:09:50,923 [DEBUG] screen_off_time : 60
23/07/18 14:09:50,923 [DEBUG] rgb_switch: True
23/07/18 14:09:50,923 [DEBUG] rgb_blink_speed : 50
23/07/18 14:09:50,923 [DEBUG] rgb_pwm_freq : 1000
23/07/18 14:09:50,923 [DEBUG] rgb_color : 0a1aff
23/07/18 14:09:50,985 [DEBUG] rgb_show
23/07/18 14:09:50,985 [DEBUG] rgb_show: colorful
------------------------23/07/18 14:15:55------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : c03112
23/07/18 14:15:55,525 [DEBUG] power_key_pin : 16
23/07/18 14:15:55,525 [DEBUG] fan_pin : 6
23/07/18 14:15:55,525 [DEBUG] rgb_pin : 12
23/07/18 14:15:55,525 [DEBUG] update_frequency : 0.5
23/07/18 14:15:55,525 [DEBUG] temp_unit : C
23/07/18 14:15:55,525 [DEBUG] fan_temp : 65.0
23/07/18 14:15:55,526 [DEBUG] screen_always_on : True
23/07/18 14:15:55,526 [DEBUG] screen_off_time : 60
23/07/18 14:15:55,526 [DEBUG] rgb_switch: True
23/07/18 14:15:55,526 [DEBUG] rgb_blink_speed : 50
23/07/18 14:15:55,526 [DEBUG] rgb_pwm_freq : 1000
23/07/18 14:15:55,526 [DEBUG] rgb_color : 0a1aff
23/07/18 14:15:55,586 [DEBUG] rgb_show
23/07/18 14:15:55,589 [DEBUG] rgb_show: colorful
