I just got started using the Raspberry Pi Pico kit and am going through the tutorials, specifically the tutorial on the centrifugal pump.
As stated in the note section (3.6 Pumping — SunFounder Euler Kit for Raspberry Pi Pico 1.0 documentation), if the pump is still running after clicking the Stop button, I need to rest the Pico by connecting RUN to ground. Is there a better way to stop the pump from running? I feel that if I have to constantly reset the Pico, it would eventually damage it. (Note: This is also an issue in 3.5 Small Fan — SunFounder Euler Kit for Raspberry Pi Pico 1.0 documentation tutorial)
Also, I connected the relay, provided in the kit, to control the pump but, I am still getting that issue with the pump still running even after the Stop button is pressed.
Any assistance on this issue would be greatly appreciated.
Thanks in advance!
