RasPi5 with Pironman5 flashing iceZero FPGA
I’m trying to flash an iceZero FPGA with icezprog using the above installation and I get writing "0x00 … 0x00ffff: [erasing] [writing….][readback.ERROR“.
I can flash the iceZero using a Pi Zero 2W with the same micro SD card.
I suspect something is blocking from the Pironman5 kit.
With “gpio readall” everything looks fine.
Does anyone have an idea what’s not working?
Many thanks and have a great new year 2025,
–Max
What you are saying is that the SD card inserted into the SD expansion board works with the PI5 connected and does not recognize the boot system properly.
We suggest that you pironman5 connect to the display to see what the display shows during the boot process and take a picture of the boot display for us to see.
What if you remove the SD expansion board and insert the SD card directly into the PI5 to boot and see if you can boot the system normally.
What is the specification of the SD card you are currently using? We suggest you provide us with a picture of the SD card for us to verify.
