I’m using Ubuntu 20.04 and every portion of the build and install went flawlessly. But the WiFi refuses to function properly when I boot from the M.2 drive. Don’t know if anyone is having the same issue with Bullseye, or if anyone can verify that the issue doesn’t exist on Bullseye. I’d be interested to know.
This issue needs to be tested, so I’ll get back to you later.
Version 22.04 and above is recommended if you are using an Ubuntu system.
Debian Bullseye systems can also be used.
Clone the system and pironman software service from the SD card to the SSD, it will function normally, and WiFi will work fine.
Use the following command to clone the system from the Micro SD card to the SATA M.2 SSD.
sudo dd if=/dev/mmcblk0 of=/dev/sda bs=4M
To wait for it to finish cloning, unplug it, then unplug the Micro SD card, connect the M.2 SATA SSD, and power up the Pironman.
