Hi all,
All the 4 USB ports on th ePiroman 5 are out of order.
I can’t use it…
Could you help please?
Any software solution? or Is it a hardware issue?
Hi all,
I can’t use it…
The USB ports are all PI5 interfaces, not the USB ports of the Pironman5 case, which does not have any USB ports.
Have you completely confirmed the functionality of the USB ports? I suggest you connect a USB flash drive to all the USB ports and then boot the system to see if it can recognize the USB drive. If it can be recognized, it indicates that the USB ports are functioning properly; otherwise, they may be damaged. You can also try connecting different USB devices to check their functionality.
If the USB ports are indeed damaged, software solutions will not resolve the issue. It would be a hardware failure, and you would need to replace the PI5 or seek assistance from a professional repair technician.
