Anyone getting SSD Gen 3 to work with Pironman5 + NVMe SSD?
I have a Samsung 990 Evo (not the pro version) and running Ubuntu on my Pi5 + Pironman5. I can’t get it to do anything higher than 31000 on the benchmark: Search Results - pironman - pibenchmarks.com - I’ve tried the override to get Gen3 but nothing seems to work.
This is my score Benchmark #90245 - pibenchmarks.com
Besides setting dtparam=pciex1_gen3, did you do anything else? Any help would be great. BTW, nice score on pi benchmarks.com.
I take a look to my boot config and I don’t make modifications on this setup, only OC.
I’ve a test and get this results, then put dtparam=nvme and dtparam=pciex1_gen=3, reboot, make second test
Have you try to OC your pi5?
This is a copy of my config.txt
For more options and information see
http://rptl.io/configtxt
Some settings may impact device functionality. See link above for details
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
Enable audio (loads snd_bcm2835)
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
Automatically load overlays for detected cameras
camera_auto_detect=1
Automatically load overlays for detected DSI displays
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
arm_freq=3000
gpu_freq=750
dtparam=fan_temp0=40000
dtparam=fan_temp0_hyst=10000
dtparam=fan_temp0_speed=127
usb_max_current_enable=1
Enable the PCIe External connector.
dtparam=nvme
Force Gen 3.0 speeds
Disable compensation for displays with overscan
disable_overscan=1
Run as fast as firmware / board allows
arm_boost=1
[cm4]
Enable host mode on the 2711 built-in XHCI USB controller.
This line should be removed if the legacy DWC2 controller is required
(e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
Got my Pironman 5 Max recently, installed one m2 port with Samsung 990PRO, the other one is empty, run the storage tests (PiBenchmarks) with gen 3 & with out gen 3 by adding ‘dtparam=pciex1 & dtparam=pciex1_gen=3’, the results are the SAME; so my conclusion is that the Dual NVMe M2 board don’t support gen 3 at all.
Well, FWIIW: Oranges/Apples (different brand WD), but my system won’t boot without dtparam=pciex1_gen=3. It will mount when booted from SD, but won’t boot from nvme. Booting from SD and measuring with hdparm gives me 890 MB/sec with gen3 enabled and 125 MB/sec with gen1. So, I think that it is working here. OTOH, with my Max5 that has 2 nvme drives in mirror RAID array it makes little difference. I assumed that was because of the pcie switch effect, it was a little less than half.
Well, 5max dual nvme uses ASM1182e 2-port PCIe x1 gen2 switch, which could not enable gen3 capability. Based on your comments, I tested booting from SD card (trixie) for both gen2 & gen3 as well; the results are, for Disk Read: 412MB/s vs 413 MB/s; Disk Write: the same as 347MB/s; these are the same results with booting from nvme SSD card.
Yes. The dual NVMe PIP module in our Pironman 5 Max does not support Gen 3; it only supports Gen 2.
This is explained in our online tutorial:
I’ve found that my Pironman5 Standard is just not capable of Gen 3.0. I went through many hours of parts and case swapping and the bottom line is that all 3 of the NVME hats I have support Gen 3.0 but I only get Gen 2.0 with the Pironman 5 case+NVME. I used the same RPi5 board and tried several SSD drives. All achieved Gen 3.0 with the other NVME adapters but only achieved Gen 2.0 with the Pironman 5 NVME case.
Other people seem to have it working, so I’m disappointed and confused. The Pironman 5 case seemed to be a great platform for overclocking and pushing the RPi5’s performance, but I have better results with an Argon One V3. It’s case gets pretty hot, but I get better CPU, GPU and NVME performance than with the Pironman. I don’t get it.
Any thoughts or suggestions?
Can you tell us the brand and model of your SSD? I had to return the Western Digital Blue 1TB and got a Samsung Evo 990.
also, make sure your config file is updated. Updated list NVME - #6 by SunFounder_Moderator
Thanks for the response.
I tried three different Gen 3.0 SSDs in the "Verified Working SSDs" list and am currently using the Samsung 970 Evo. My config file is updated with “dtparam=nvme” and “dtparam=pciex1_gen=3”. This same RPi5 with the same SDD drive works at Gen 3.0 speeds with the Argon case and two other NVME hats.
Well, magic happened. After a fresh install of Ubuntu+KDE Plasma and updating the config.txt file and am getting “8GT/s” and 773MB/s from hdparm. Easy as can be.
I spent many hours last week trying to get this to work, duplicating images, swapping out NVME hats and SSD drives. I verified the config.txt files on every boot.
I’m going to keep this golden image on my Samsung 970 Evo and see if I can get PCIe 3.0 working on another SSD in the “verified” list.
Again, thanks magc for your response.
Post your benchmarks! That’s pretty good performance!
And then magic unhappened, but I think it was a solder issue on the Pironman5 NVME hat. I ended up with the same issue with Gen2 or even Gen1 speeds after cloning the SSD to an identical SSD and swapping them. I ended up reflowing the solder on the M.2 connector even though it looked fine under a microscope. I am now getting solid Gen 3 speeds.
I just wanted to document this somewhere. Sorry for the distraction folks!
