hi
I have problems with lesson 17 and 18 in Raphael kit. I think its the liberary ADC0834, the compiler writes that it is shadowing? I use the rasberry kit.
any suggestions?
thanks in advance
- What issues did you encounter when running Lesson 17 and Lesson 18? Did you experience any errors when running the code? If so, please provide a screenshot of the error, so that we can analyze and help resolve the problem.
2.Please carefully check the wiring to ensure it is correct. The ADC0834 module has a specific orientation when connecting it to the breadboard. You can observe the lettering on the ADC0834 - the orientation is correct if the letters are facing you.
i solved the problem in later lessons thanks
