I tried using a 5v 3.5amp and now a 5v 4amp adaptor on the pironman board and it seems it sees the ssd for a sec then doesn’t. I tried using one adaptor on the pi and one on the pironman board and same difference. I also tried with wifi/bt turned off and using only rj45 connection, no usb keboard or mice either.
NVM SSD WD Green (pi gui copy program saw it once as Samsung MZNTY128HDHF-000 But fails to copy. Its specs says 5w and 110mW so not sure why the usb3 port @ 1amp can’t power it.
from amazon: Western Digital 1TB WD Green SN350 NVMe Internal SSD Solid State Drive - Gen3 PCIe, QLC, M.2 2280, Up to 3,200 MB/s - WDS100T3G0C
84.699994] usb usb2-port1: over-current change #1
[ 84.798029] usb 1-1-port1: over-current change #1
[ 84.915851] usb usb2-port2: over-current change #1
[ 85.017873] usb 1-1-port2: over-current change #1
[ 85.131759] usb 2-2: USB disconnect, device number 2
[ 85.355920] usb usb2-port3: over-current change #1
[ 85.459768] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
[ 85.571904] usb usb2-port4: over-current change #1
[ 85.787963] usb usb2-port1: over-current change #2
[ 86.149555] usb 1-1-port3: over-current change #1
[ 86.284121] usb 2-2: new SuperSpeed USB device number 3 using xhci_hcd
[ 86.305325] usb 2-2: New USB device found, idVendor=152d, idProduct=0580, bcdDevice= 1.00
[ 86.305345] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 86.305350] usb 2-2: Product: USB Mass Storage
[ 86.305353] usb 2-2: Manufacturer: JMicron
[ 86.305357] usb 2-2: SerialNumber: 152D00580000
[ 86.311890] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 86.312184] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0580: 800000
[ 86.312317] scsi host0: usb-storage 2-2:1.0
[ 86.371391] usb 1-1-port4: over-current change #1
[ 87.328345] scsi 0:0:0:0: Direct-Access JMICRON JMS580 PQ: 0 ANSI: 6
[ 87.329465] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 87.332654] sd 0:0:0:0: [sda] Unit Not Ready
[ 87.332674] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 87.332678] sd 0:0:0:0: [sda] ASC=0x20 ASCQ=0x0
[ 87.335668] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=DRIVER_OK
[ 87.335686] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 87.335690] sd 0:0:0:0: [sda] ASC=0x20 ASCQ=0x0
[ 87.337811] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 87.337826] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 87.339474] sd 0:0:0:0: [sda] Write Protect is off
[ 87.339494] sd 0:0:0:0: [sda] Mode Sense: 00 00 00 00
[ 87.340132] sd 0:0:0:0: [sda] Asking for cache data failed
[ 87.340147] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 87.340928] sd 0:0:0:0: [sda] Attached SCSI disk
[ 142.468329] sd 0:0:0:0: [sda] Unit Not Ready
[ 142.468362] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 142.468371] sd 0:0:0:0: [sda] ASC=0x20 ASCQ=0x0
[ 142.472594] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x00 driverbyte=DRIVER_OK
[ 142.472618] sd 0:0:0:0: [sda] Sense Key : 0x5 [current]
[ 142.472625] sd 0:0:0:0: [sda] ASC=0x20 ASCQ=0x0
sudo lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
Linux piman 6.6.22-v8+ #1746 SMP PREEMPT Wed Mar 20 17:19:49 GMT 2024 aarch64 GNU/Linux
Please Help.
Adams
