Pironman has speakers plugged into Pi4 8gb. Speakers make noise with each mouse click. When the speakers are plugged in and selected as Audio Out, You tube will stop working.
Raspberry Pi 4 with 8gb
240gb SATA SSD
Raspberry Pi OS with all latest updates.
- Since the PWM used by the ws2812 RGB light conflicts with the PWM used by the Raspberry Pi 3.5mm audio output, the two cannot be used at the same time GitHub - jgarff/rpi_ws281x: Userspace Raspberry Pi PWM library for WS281X LEDs
- You can use HDMI audio, or turn off the RGB lights of the Raspberry Pi: sudo pironman -rw off
